Max BR1 mini, but it applies to others.
On firmware 8.2.1. Check for update says 8.6.1, with an upgrade button. But it won’t work - you need to go to 8.6.0 before you can go to 8.6.1. Some devices, you need to have 8.5.4 in the upgrade path. There may be other required stops along the way, depending on the device.
Surely, Peplink can figure out how to present the next firmware which is actually possible when someone checks for upgrades, instead of blindly offering the latest. i.e. unless a device is already on 8.6.0, don’t offer 8.6.1 as an upgrade.
