I have two locations that have b-one-5gs and I use the PepVPN tunnels to connect two networks. From time to time I look at the logs and there are entries that are repetitive but with no detail or explanation. Everythig seems to be working ok, but there is also a lot of disconnect - reconnects that seem to occur and there isn’t a log entry for the tunnel going down. May I ask for a laymens explaination?
I see the following:
| Date/Time | Type | Details |
| 7/24/25 11:39 | PepVPN | conn_to_B_ONE_5G: Initiated TLSv1.3 connection to xx.xx.xxx.xxx using cipher suite TLS_AES_256_GCM_SHA384 |
| 7/24/25 11:39 | PepVPN | conn_to_B_ONE_5G: Initiated TLSv1.3 connection to yy.yy.yy.yyyy using cipher suite TLS_AES_256_GCM_SHA384 |
| 7/24/25 11:39 | PepVPN | Accepted TLSv1.3 connection from yy.yy.yy.yyyy using cipher suite TLS_AES_256_GCM_SHA384 |
