When found that certain carriers require the port to be forced to 100Mbps Full Duplex to realize the full internet speed. When we select this mode from Auto, the connection fails. The only way around this is to use a switch in between the Peplink and the ONT handoff.
Tested on All Balance Series and SOHO
Carrier: AT&T Fiber Circuit.
Can someone from Peplink confirm this is an issue? The workaround is messy and having to explain it to other MSPs is a bad look for us who has standardized on this product.
By right, auto negotiated port speed with 100Mbps Full Duplex or enforced 100Mbps Full Duplex manually shouldn’t have the different. I worry other factors affect your throughput. I suggest opening a ticket for us to take a closer look.
I agree, it shouldn’t happen but when I force 100 Mbps FD, the connection drops completely.
I’ve opened a ticket with our distributor but it’s difficult for us to be able to test since we don’t have AT&T in house. The distributor lacks the lab for replicating the scenario and for us to test it we would have to bring a customer down and pay for a technician to be on site.
Please treat the low throughput and port sync/compatible issue as 2 different cases.
For the low throughput issue when WAN port set as Auto, please open a ticket to us. I believe the reason of fixing the port speed is due to you can’t get the actual throughput.
For port sync/compatible issue, it should relate to the ethernet chipset from different brand. Since Auto port speed works well in your enviroment, I suggest focusing to the low throughput issue at this stage.
