I replaced my Cradlepoint MBR 1000 with the Pepwave Surf SOHO primarily for the ability to monitor bandwidth usage at the router level. One of the features I miss from the Cradlepoint is the ability to see the signal strength of the modem using the admin function of the router. That would be cool to have in the SOHO.
Posting this as a feature request was suggested by the folks at 3GStore
Tag on bottom says Surf SOHO- product code is SUS–SOHO. Serial number is 2830–DFF9– 8124. Using product at home and is working great. hope this information helps.
Thanks Don. How about the make and model is your USB LTE/3G modem? We will be looking into supporting this feature for all compatible USB modems of course but knowing which one you have on hand is a good starting point.
