I just purchased the Pepwave Surf SOHO MK3 and was wondering if I can replace my antennas with higher gain antennas? I did find a couple of forum articles but there really weren’t specific enough. Thanks.
You sure can, just make sure they are dual-band compatible. Thanks.
