I have a Pepwave Surf SOHO Mk 3. I was using it as a wifi AP to connect from my ZTE Mobley in my RV to connect more devices to my network. I recently got a Winegard ConnecT 2.0 and set it up. The ConnecT2 will eventually replace the Mobley when we get around to buying a SIM card and data plan that it supports, but for now, its going to be the device that connects to the outside internet through Wifi at campgrounds.
I don’t want to stop using the Surf SOHO though, since it has ethernet ports and the ConnecT does not. I have a few devices that I would rather connect over ethernet, just because its easier that way and faster. I’m just not sure how to do that and have it all visible on the same network.
Since the ConnecT’s antennas are much better than the SOHO and its mounted on the roof, it can see wifi networks much farther away. So if I want to run everything through the ConnecT in the end.
If I set it up like this wifi network > ConnecT > SOHO > devices, and I have everything connected to the SOHO SSID, either through ethernet or wifi, will they all be able to see each other? Or if I want to connect devices straight to the ConnecT, but have ethernet devices connected to the SOHO, is there a way to make them visible to each other? Would I need to set up port forwarding or something?
I’m trying to find the best way to set this all up so the end devices only need to connect to the same network all the time (which would probably be easies through the SOHO). Also, if I get a ethernet switch, will the devices on that, if connected to the SOHO, be visible on the same network as well? The SOHO only has 4 LAN ports, and I might need a couple more than that. I’m trying to run as much as possible off ethernet if I can.
