Pepwave Surf SOHO as VPN Client
Will the new Pepwave Surf SOHO MK3 feature a VPN client?
The reason for asking is because as far as I understood previous models didn’t support it, but it’s becoming more and more evident that having a router, which centralises all the network traffic, that supports VPN connections to VPN providers (like ExpressVPN or others) is a far better solution than having separate connections per node.
I would love to see such feature on it, not just site-to-site.
Cheers
We do support as VPN server only. I will move this to feature request for product team to take consideration.
Thank you.
I would love to see this feature on the Surf SOHO. I currently use the Surf SOHO as my main connection to APs (mostly open WiFi) at RV parks around the nation. I currently have some of my most used clients (PCs, phones, pads) using a VPN service for security reasons. As I have many clients I test while roaming around, I would benefit from simply using the SOHO as the one VPN client conveniently protecting everything. Prefer OpenVPN, IKEv2/IPsec support.
Hi Jim. Just curious: Do you have a Peplink router (any type) at home [or elsewhere]? If so, you can set up a persistent PepVPN between the devices – problem solved! :<)
My RV is my home, so no. I rely NordVPN.
