Hello;
I am trying to configure a Surf On-The-Go : My WAN side 5Ghz and my local WAN with 2.4Ghz.
I don’t want a way to execute this.
Question - Is the Surf On-The-Go only can serve one band - 2.4 or 5, not both at the same time?
Rom
Hello;
Rom
Surf On-The-Go can operate either 2.4Ghz or 5Ghz. It does not operate both bands at the same time. You can select either band based on your requirements.
I hope this information helps.
Hi Rom, the Surf On-The-Go is dual band capable but not simultaneous. You need to choose either 2.4 or 5, but not both at the same time.
This has come quite handy. I have been trying to increase comments on my site to get some search engine love.
