Looking for suggestions on antennas you could attach to the SOTG to help boost range in receiving a signal. Most likely to be used on board boats in different marinas with varying Wi-Fi networks. Open to any and all ideas. Thanks.
Not sure whether SOTG is the best option for the Marine deployment that include different type of WAN fail over. Would you please check on the design lab below for the overall design ?
