I’m a bit confused …
I have a Pepwave Surf On The Go. If I look at this page (http://www.peplink.com/products/pepwave-surf-on-the-go/), it states InControl is possible.
However, on the InControl admin-page (‘add devices’ page), it says:
InControl 2 can check the warranty status of the following devices:
- Peplink Balance family
- Pepwave MAX family
- Pepwave Surf SOHO
- Pepwave Access Points
For InControl 2 to manage a device, it needs to meet the following criteria:
- Device needs to be in warranty
- Device needs to be in the Balance or MAX family
- Device needs to run Firmware version 6.1
Neither of these conditions are met by the Pepwave Surf On The Go, I believe? If I try to add my Surf OTG in InControl, it says it can’t.
So my question: am I wrong, mistaken? Or is the product page wrong? I hope I am wrong, because I’d really like IC with my Surf OTG.
