I have the pepwave surf 200 and want to hook my Ipad2 but the first thing it says is to connect the Ethernet cable to the surf 200 and then to the computer,but the I pad doesn’t have a Ethernet port.So how do I do it? I do have a windows machine If that would help.I’m not sure what the Ethernet connection does to the computer;Drivers for the machine or just to recognize the network.If that’s what it’s doing the wouldn’t the windows machine work for set-up?
If this is first time setup of the unit, then I would directly connect your windows machine via ethernet to the AP and configure the Wi-Fi settings. Once done, you should be able to connect no problem via wireless with your Ipad2.
