Hi all first post here I’m slowly learning about cellular bonding!!! My first project would be to have 4 USB 4G/LTE USB modems to be connected to a laptop for video file transfer. I think the Pepwave Max On The Go would work but do I need something else? Does the Max On The Go plugs in straight into a laptop or I need something in between? Also do I need something at the other end? I was reading that it needs something like the Pepling Balance 210 Load balancing/bonding router. Not sure where that goes into the transmission path!!!
Would be for live streaming and actual file transfer to my clients I do audio and video editing and I work on the field and I need a fast a reliable way to send my material over. I’ve noticed that the MOTG doesn’t do bonding only load balancing.
Thanks this is great!!! But basically I would need a balance module at the other end no matter what? Even if I feed the material to people not connected to the VPN? Might be the wrong thread but I see on that diagram that you need a video encoder for live broadcast I have a 15" Mac book Pro with a Matrox mxo2 would there be a way to plug my camera HD/SDI to the Matrox (which I do to record all the time) and use a software base encoder to encode the A/V signal to be pushed live thru the MOTG?
