I just bought a used unit cause it’s what I can afford. I’m using a chromebox (really just a laptop running chrome os). I’m trying to connect to address in the manual but it’s not working. the manual says to log onto 192.168.0.3 but to no success. Any suggestions?
ok, so i’m now able to see the configuration pages and i can see the nearby networks, however, i am not able to select any one of them to connect to it. here is a screenshot…
The OfficePoint 400 is a dedicated access point that creates Wi-Fi networks and is not a client device that would connect to an existing network. What are you trying to accomplish?
What I’m trying to do is used it similar to the way I used to with the Pepwave surf n go. I just want a way to use it to connect to say McDonald’s wifi and broadcast it to my kids computer securely.
