Does anyone have resources on disassembling this router to replace the modem? I’ve removed all screws, but not really sure how the housing is removed.
Hello…
You know… your warranty was gone… correct?
The TST DUO, have two LTE MODEM, one in each side of the main board.
Also… you have a small connector between all boards…
Pay close attention when disassembling and then assembling, otherwise you will lose your equipment.
Way past warranty time.
Ok thanks great picture, I just have the single cat 18 version.
Does it slide out?
I really don’t know… I just have the tst duo version. (two lte modem)
Mine have a litle slot… look the picture…
top side of the silver board… a screw.
down side of the silver board… a black slot.
