Hello all,
We are using a local instance of IC2 to control a bunch of Max Transits LTEA.
Under Settings > Device System Management there is the possibility to configure CLI SSH & Console access on both LAN / WAN interface.
It is clearly written in the web interface that that option is only applicable to Peplink Balance and “Pepwave MAX” only.
Can we well consider that the “Pepwave MAX Transit LTEA” is well part of “Pepwave MAX” familly?
Is the SSH access on the WAN interface possible when using cellular network (and not the WAN port interface) located on the router?
Many thanks in advance,
Best regards,
Jerome
