We have a PEPWAVE Max Transit Duo LTEA and needs to be enclosed on a weather-proof box. What is the maximum temperature can it take?
SDCOMM
SDCOMM
Operating temperature range is on the data sheet:
Says the valid range is -40c to +65c so depending on your external environment you may need to consider a case with some ventilation.
Thank you WillJones. Will monitor its temperature condition as no ventilation can be installed. Otherwise, salt water from sea-spray will get into the weather-proof box.
