I purchased the ACW-622 56V Power Supply for POE+ from a PepWave distributor. They ensured me that this was the correct power supply for my MAX HD2 revision 2 and 4 units.
However, I’m noticing 2 issues with the POE+ power supply unit:
- I am hearing a buzzing sound inside the HD2 when the POE+ power supply unit is connected.
- The POE+ option on each LAN Port is not available.
Is this the correct POE+ power supply for my revision 2 and 4 MAX HD2?
Do I need a license to activate POE+ on each lan port?
