I am having issues with my Wi-Fi AP on the Pepwave MAX HD2 LTE. Firmware v7.0.0 build 2742 Support Ticket #774218
Wi-Fi speeds are 0 - .5 Mbps while LAN speeds are around 15 Mbps
If you Disconnect the LAN ports from the Netgear switch the Wi-Fi Speeds are normal at 15 Mbps.
This setup is a bit unique as our server rack is setup at the race track every weekend in a new country, so diagnostic time is minimal as we only have about 4 days this system is fully up and running per week. Breakdown is as follows:
Alkamel supplies timing and internet via a Mikrotik RB2011UiAS-2HnD-IN 10 port router. This router setup is locked down and I have no access to the admin settings within this device due to having other race team’s data distributed through the Alkamel system. Mikrotik IP Address is 128.127.1.1.
The Mikrotik connects to the Pepwave via the WAN1 port.
The Pepwave connects to a Netgear GS748TV5 48 port switch via 1-4 LAN ports
Pepwave Admin settings are mostly default.
WAN Connection Details:
IP Address 128.17.1.10
Subnet Mask 255.255.255.0
Default Gateway 128.127.1.1
Connection Method DHCP
DNS 128.127.1.1
LAN Connection Details:
IP Address 192.168.50.1
DHCP Enable
DHCP Reservations on two devices
Port Settings:
LAN Ports 1-4 Enable
Speed Auto
Advanced Settings have not been touched at the moment.
AP Controller is set to Integrated AP only
WPA/WPA2
Enable is Always On
VLAN Untagged LAN
Broadcast On
Data Rate Auto
Multicast Rate MCS7/54M
IGMP Snooping Enabled
Max Clients 0: Unlimited
Band Steering Disable
Restricted Mode None
AP Settings:
2.4GHz only as 5GHz is illegal in our series
Operating Country Germany
Preferred Frequency 2.4GHz
Channel Width Auto
Channel 13 (I have tried all channels, but this has the least interference)
Output Power Fixed: Max with Boost enabled
Signal Strenth Unlimited
Max Clients Unlimited
Management VLAN ID Untagged LAN (No VLAN)
Wi-Fi Operating Mode WAN/AP (Have tried AP/AP with same results)
AP Advanced Settings are all set at Default
Any help is much appreciated.
Cheers!
