I try to connect my MAX BR1 Pro to a WiFi WAN Connection. After scanning I select the correct SSID and enter the correct password but afterward the status changes to “Connecting…” and then gets stuck on that status. It seems it never tries to get an IP even though it’s set to DHCP. I tried different SSID’s but none works?
Any ideas what the issue could be and how I can fix this?
Thank you
