is it possible to create a MESH network with the Pepwave MAX BR1 Pro 5G and us EERO wireless AP’s?? would prefer everything be wireless since we have no way to run network cabling to the AP’s from the router…
You might be able to by attaching one EERO via ethernet close to the MAX and then using others in a mesh. I doubt you can use the native MAX wifi network to be part of an EERO mesh.
