There are two ports on the unit, Wifi Antenna A and B. Which one is used for the AP for wifi connected devices? I think one is for WiFi as a WAN option and one for the access point for internal devices.
its all shared on the MK2. both ports do both bands and WAN and LAN AP
I highly suggest if you are doing WiFi WAN to use the MK2 for only WiFi WAN and then get a second LAN AP connected via ethernet
thanks for the speedy response!
I have a Poynting 5-in-1 MIMO 2xLTE, 2xWiFi, 1xGPS outside our office. I have all 5 ports on the BR1 connected to the antenna. I was hoping I could disconnect either A or B from the Poynting and attach one of the paddle antennas that was part of the BR1 kit. My thinking is that this would provide a stronger signal to internal devices while still allowing the BR1 to be able to connect to external WiFI as a possible alternative WAN.
Thoughts?
no
again, read my response. now especially if you have an external antenna, separate the wifi wan and lan. keep wifi wan on the external antenna and get a separate ap for the internal lan.
