Hi all,
I am running Model: Pepwave MAX BR1 MK2
Firmware: 8.0.0s061 build 1436
I don’t want to upgrade the firmware yet…too soon, waiting for bugs to be worked out.
I have an ATT sim in slot A and a verizon sim in slot B.
The Verizon sim only connects when I have the settings as below:
I have seen SIM Pin required (on a SIM with no PIN set) when the SIM is not seated properly. Might be worth popping it out, cleaning contacts and putting it back in.
If its one of those SIMs that you can push out the chip to make it smaller (down to nano size) stick a bit of clear tape on the back of the sim to hold it all together (this also makes it slightly thicker which helps with the contacts).
Swap the SIMs with each other and see if the fault follows
Test the SIM in your mobile/cellular phone.
Sometimes SIM Cards do fail, we have some every year that need to get replaced (normally older SIMs or SIMs in extreme environments), the SIMs are electronic chips, and just like all electronics, they can fail from time to time.
Happy to Help,
Marcus
@Troy, it seems like a bug of the old firmware. Please set the Network Mode to Auto to confirm it helps. If not, please upgrade to the latest firmware version.
I am using 8.3 Firmware and just had the same issue with a simcard which works in my phone. Switching from “Auto” to “Generic” solved it. Thanks for this tip
