Hi ,
i have created two vlan in each LAN but i cant bind the layer 2 vpn profile in different vlan.( I mean one profile two vlan share .)
L2 profile’s can only include one VLAN/Lan segment on each device. Share a diagram of what you are looking to achieve.
Router holds the gateway.Each pepwave lan create layer 3 interface and bind to the layer 2 vpn ( I created subinterface based on the diagram). Any solutions ?
It’s possible ??
Yes that’s possible. You would add two vlans to both BR1s. Then create two Layer2 PepVPNs between each pair of VLANs.
Assuming IP Addresses / subnets are different for VID 20 and 60.
Hi Martin,
Im appreciate for the support. I have a questions regarding create two Layer2 PepVPNs profile cannot bind in the same local id. Any solutions?
Thomas
I tried before I really can’t bind same local id in different layer2 profile .
@thomasthoo, since you opened ticket on this, we will follow up with you there.
