We have a dosen of routers placed around town with 2-3 clients connected to them. I manage all the routers through InControl2 and they have the latest firmware (8.1.3. build 5077).
Randomly, clients drop Wifi connection and cannot connect. I went to one of the places and used Wifi Analyzer. The SSID is present with good signal strength, but I could not connect to it.
Any idea why this keeps happening?
AP settings is_
WPA2 - personal
802.11ng
No boost, but 100% power.
Channel 11.
This is the log from one of our client the moment it got disconnected.
Time message process.name
Aug 12, 2021 @ 16:05:49.000 wlp3s0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Audhumbla" auth_failures=8 duration=90 reason=CONN_FAILED wpa_supplicant
Aug 12, 2021 @ 16:05:48.000 wlp3s0: SME: Trying to authenticate with (SSID='Audhumbla' freq=2462 MHz) wpa_supplicant
Aug 12, 2021 @ 16:05:40.000 wlp3s0: CTRL-EVENT-SSID-REENABLED id=0 ssid="Audhumbla" wpa_supplicant
Aug 12, 2021 @ 16:04:10.000 wlp3s0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Audhumbla" auth_failures=7 duration=90 reason=CONN_FAILED wpa_supplicant
Aug 12, 2021 @ 16:04:10.000 wlp3s0: CTRL-EVENT-SSID-REENABLED id=0 ssid="Audhumbla" wpa_supplicant
Aug 12, 2021 @ 16:04:10.000 wlp3s0: SME: Trying to authenticate with (SSID='Audhumbla' freq=2462 MHz) wpa_supplicant
Aug 12, 2021 @ 16:02:38.000 wlp3s0: SME: Trying to authenticate with (SSID='Audhumbla' freq=2462 MHz) wpa_supplicant
Aug 12, 2021 @ 16:02:38.000 wlp3s0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Audhumbla" auth_failures=6 duration=90 reason=CONN_FAILED wpa_supplicant
Aug 12, 2021 @ 16:02:00.000 wlp3s0: CTRL-EVENT-SSID-REENABLED id=0 ssid="Audhumbla" wpa_supplicant
Aug 12, 2021 @ 16:00:59.000 wlp3s0: SME: Trying to authenticate with (SSID='Audhumbla' freq=2462 MHz) wpa_supplicant
Aug 12, 2021 @ 16:00:59.000 wlp3s0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Audhumbla" auth_failures=5 duration=60 reason=CONN_FAILED wpa_supplicant
Aug 12, 2021 @ 16:00:20.000 wlp3s0: CTRL-EVENT-SSID-REENABLED id=0 ssid="Audhumbla" wpa_supplicant
Aug 12, 2021 @ 15:59:19.000 wlp3s0: CTRL-EVENT-SSID-REENABLED id=0 ssid="Audhumbla" wpa_supplicant
Aug 12, 2021 @ 15:59:19.000 wlp3s0: SME: Trying to authenticate with (SSID='Audhumbla' freq=2462 MHz) wpa_supplicant
Aug 12, 2021 @ 15:59:19.000 wlp3s0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Audhumbla" auth_failures=4 duration=60 reason=CONN_FAILED wpa_supplicant
Aug 12, 2021 @ 15:58:49.000 wlp3s0: CTRL-EVENT-SSID-REENABLED id=0 ssid="Audhumbla" wpa_supplicant
Aug 12, 2021 @ 15:58:49.000 wlp3s0: SME: Trying to authenticate with (SSID='Audhumbla' freq=2462 MHz) wpa_supplicant
Aug 12, 2021 @ 15:58:49.000 wlp3s0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Audhumbla" auth_failures=3 duration=30 reason=CONN_FAILED wpa_supplicant
Aug 12, 2021 @ 15:58:28.000 wlp3s0: CTRL-EVENT-SSID-REENABLED id=0 ssid="Audhumbla" wpa_supplicant
Aug 12, 2021 @ 15:58:28.000 wlp3s0: SME: Trying to authenticate with (SSID='Audhumbla' freq=2462 MHz) wpa_supplicant
Aug 12, 2021 @ 15:58:28.000 wlp3s0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Audhumbla" auth_failures=2 duration=20 reason=CONN_FAILED wpa_supplicant
Aug 12, 2021 @ 15:58:18.000 wlp3s0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Audhumbla" auth_failures=1 duration=10 reason=CONN_FAILED wpa_supplicant
Aug 12, 2021 @ 15:58:17.000 wlp3s0: SME: Trying to authenticate with (SSID='Audhumbla' freq=2462 MHz) wpa_supplicant
Aug 12, 2021 @ 15:58:09.000 wlp3s0: SME: Trying to authenticate with (SSID='Audhumbla' freq=2462 MHz) wpa_supplicant
Aug 12, 2021 @ 15:58:08.000 wlp3s0: SME: Trying to authenticate with (SSID='Audhumbla' freq=2462 MHz) wpa_supplicant
Aug 12, 2021 @ 15:58:08.000 wlp3s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=CN wpa_supplicant
Aug 12, 2021 @ 15:58:07.000 wlp3s0: CTRL-EVENT-DISCONNECTED bssid= reason=2 wpa_supplicant
