Hello!
I am just in the phase to roll-out some Pepwave APOnes, which I control with my PepLink 580 router. I have managed to setup the “captive portal” to enable dedicated access for guests to our guest wlan - that works all fine!
Now my question:
Is “Guest Protect” only available in the latest firmware for the 580? I am currently running 5.3.9 build 1676? And I don’t see that option within the router’s web-interface.
Secondly: if I check “Block all private IPs”, do I need to add an exception for the peplink-router itself to enable web-browsing etc. for guests? Or will that be done automatically?
Bjoern
