i have a pepwave BR2 with two starlink antennas connected to WAN 1 and WAN 2, the Starlink connected to WAN 2 connects just fine and is set to DHCP. The starlink on WAN 1 will not connect, it just says ‘Connecting’ but never actually connects.
does anyone have any suggestions as to why this is? when i connect my laptop directly into the antenna it connects straight away so there isnt an issue with the Starlink. Both WANs are configured in exactly the same way.
I have a BR2 Pro and starlink and also have similar experience.
Occasionally starlink will just stop working and when I look at the BR2 webmin I see the “Connecting…” - the only resolution I have found is to power cycle the starlink.
Is your BR2 connected directly to the Dish? Or are you using the starlink router+ethernet dongle? My BR2 is connected directly to the rectangular dish without their router in between.
