Hi everyone,
I’m currently in Greece and experiencing a persistent issue with my Pepwave MAX-HD-MBX-GLTE-G, which is connected to a Pepxim SIM Injector.
I’ve tried using three different local Greek SIM cards (Vodafone Greece, Cosmote, and Nova), but none of them are able to establish a connection. The device stays stuck on “Obtaining IP Address”, even though APN settings are correctly configured.
To rule out issues with the SIMs themselves, I tested all three in a Samsung smartphone, and they all work perfectly, with immediate data connection. Additionally, when I insert my Italian SIM card into the Pepwave unit, it connects and works without any issue.
I faced the same issue the past summer here in Greece with a Vodafone SIM Card but after that i bought a Cosmote card and it worked immediatly. But this year it seems that any SIM isn’t working in the system.
Has anyone else experienced this behavior while in Greece? Are there any known compatibility issues or configuration tips for using Greek SIMs with Peplink devices?
Any help would be greatly appreciated.
Thanks in advance!
ALESSANDRO GAMBONI
