Dear Guys ,
Please someone explain for me how PepVPN support dynamic IP environment and how it works … Does it mean that we can have dynamic IP at both sides or still one side needs static IP ?
Thanks - Hootan
Dear Guys ,
Thanks - Hootan
Only the WAN set to priority 1 will be used for sending the data through the SpeedFusion VPN. The priority 2 WAN will build a tunnel and only be used when WAN 1 goes down.
You will still need a static ip on one side.
The remote IP address field in configuration also accepts DNS names. So you could also use dynamic DNS on any side to receive VPN connections.
-Jonan
If the modem does a NAT on the dynamic DNS side, it must be set up to forward ports to the Balance.
Noted Guys…
Thanks so much.
Best regards.
