We have an install with a pair of Balance 580’s in HA. When setting up a PepVPN through InControl, for the hub it gives the choice of selected 1 of the units. I picked the Master but was a little confused in that it showed both units. Is that right that I should select the Master Balance Unit for the hub and let the sync handle pushing the config to the slave? I just want to make sure that the PepVPN tunnels stay up during a failover.
John
