I have two PepWave Max BR1 Minis that I’m trying to connect over PepVPN, but they’re stuck on “Updating Routes…” I see this is a fairly common topic in the forum, but I haven’t found an answer that works for me. I see in the PepVPN status that they’re able to recognize the remote ID and device name of the other, but I’m not able to ping a computer on one network from the other network. Both are using their cell connections, and I set the VPN connection priorities to OFF for WAN and Wifi WAN. I’ve tried to eliminate sources of conflict giving them different DHCP ranges (but both using 192.168.50.xxx). I also tried changing the LAN address for one of them from the default 192.168.50.1/24 to 192.168.50.101/24, while leaving the other at 192.168.50.1/24. Interestingly, this changed the PepVPN status to “Route Conflict”, with a yellow dot instead of red. I don’t know what it means, but seems like evidence of something!
These devices are brand new, so aside from this, I don’t think anything has been changed from its default. Thanks for any help!
