I finally have my Balance 30 Pro connected to my FusionHub EC2 instance.
I noticed something strange and I wonder if it’s by design or some wrong setting of mine:
The balance 30 Pro has three WANs, that when speedtested directly (without the peplink) one at a time give me these speeds:
- an FWA 100/20
- Starlink, 160-270 / 20-40
- Mikrotik LTE modem 5-30 / 5-30
Before setting up the FusionHub, I had them all “Always on” in Load Balance. Speedtest from a PC in the lan would give random speeds as expected, depending on which WAN was assigned at the moment to the PC.
After I setup PepVPN, I did as testing an outbound policy in the Balance Pro Enforcing PepVPN WAN for one particular IP (my test PC).
speedtest.net would give me correctly the Elastic IP and speeds like 70/40, with or without AES256 enabled in InControl2 (shouldn’t it be faster without AES256?)
Now when I go to SpeedFusion status page and I run the upload/download test, it seems like it’s testing only one WAN at a time: is this normal? Is it combining ALL the WANS in the Fusion tunnel?
Here it shows all three connections connected (Always on, priority 1)
Here instead, after pressing Status, only one is green and the others show in yellow, one disabled and one back up:
But here they are set all as Always on:
Here, where I do the test, again only one at a time, and I can actually chose which one to test but never all together:
Why is the PepVPN status page not showing all the 3 connections green, where else they could have been one “manually disabled” (EOLO) and one set as backup (LTE) ?
How do I test the total combined throughput of all WAN’s together, assuming that the FusionHub is actually getting traffic from all 3 wans? How can I make sure that is happening, otherwise?
Thank you!
