Would be nice to be able to have the PepVPN data port rotate through a set range of port numbers if the VPN connection has trouble connecting or disconnects.
Our use case here is that we are connected through a client provided guest network with other contractors and it seems that there is either some aggressive UTM or another contractor competing with the same port(s). If we change the port number after a disconnect, the link will re-establish.
