I have been searching the forum for a link or knowledge base document with instructions to setup a standard VPN and Layer 2 PepVPN between and ENT and LTE router, using Verizon Wireless. Alas I have come up empty handed.
We currently have an established Layer 2 PepVPN network, using Verizon Wireless (our only network option) using a MAX_BR1_ENT as a hub for 7 connected MAX_BR1_LTE field devices. We need to split that network, isolating two operations. To do so, we purchased two new MAX_BR1_ENT units and a 20 peer VPN license. One of the ENT units will become the new hub for 4 of the LTE units. Every ENT and LTE router has it’s own Fixed IP Address.
I did not set up the original PepVPNs so I don’t know how it was done, though I can look at all 8 devices to see how they’ve been configured. Using that information, I tried to build a Layer 3 PepVPN between the two new ENT routers, for practice, though they will not connect. My assumption is I have to establish a Layer 3 VPN before converting it to Layer 2.
Does anyone have the procedure to set up PepVPNs across a Cellular network?
Thank you,
Steve C., IPWarrior
