I would like to rdp to a remote PC behind a PepVPN by computer name rather than IP address, since some of them use DHCP.
How do I set up the local/remote vpns so that the computer names are resolved at the remote site’s DNS server? Right now, if I try to ping a remote computer name, it is not found; but it is ping-able by IP address.
Thanks TK. I think I’ve set this according your instructions, but I could not ping from the HQ side by computer name. Then I realized that DHCP on the remote side was not working, since one of the PCs could not get an address.
Do you mean PC A (at HQ) can’t ping hostname of PC B (at HQ)? If both PB are under same network (same broadcast domain), then is nothing to do with Wins.
Your settings are correct. Please ensure remote side PC can grab IP from Balance router. You may need to check the network connectivity there.
I am at 192.168.10.0/24 trying to ping hosts on 192.168.1.0/24. The 192.168.1.0 LAN is an Active Directory domain. The one where I’m at, 192.168.10.0, is just a peer LAN.
While logged onto 192.168.10.12, I can ping any host on 192.168.10.0 either by IP or hostname. From this same host, I can ping any PC at 192.168.1.0 by IP, but not by hostname.
I tested it is working. Please ensure both PCs are pointing to WINS server 192.168.10.1 (check using ipconfig/all if you are using Windows PC) and reboot both PCs and test again.
If steps above doesn’t help, please open ticket for us to take closer look.
