I have a Surf Soho with PEPVPN enabled at home. There is a raspberry pi that I have connected to the network, but I forgot to create a static ip for it before I left. The dynamic ip has since changed and I do not know what it is. I was wondering if there was a way I could find get a list of connected clients through PEPVPN so I could get the new ip address and login via SSH. I will not be home for several months.
I assume you connected to Surf Soho remotely with PepVPN. If so, you may connect to Surf Soho Web Admin with it’s LAN IP (default is 192.168.50.1). Then navigate to Status > Client List to check for the connected clients.
Hope this help.
