Already bought an outdoor antenna, but still not sure how to get the best possible performance? Try these tips as the possible factors affecting the performance include cable length and the diversity of the antenna.
Time to upgrade your connectivity by taking some little steps. Follow us and stick around for more upcoming sharing!
The use of technology and automation in logistics isn’t too new, but what has made and still makes this possible is the constant connectivity backing it up, especially across different branches of warehouses, factories, and offices. Stay tuned for future posts to see how Peplink makes logistics connectivity always work.
How do I find the right one? Not the right person… but the right antenna!
Make your choice based on your needs and where you’re going to use it! Don’t worry about whether you’re being too picky. These Peplink outdoor antennas are specially designed for different situations, and you can always find the most suitable one among them!
Despite the recommendation, the Mobility Series and the Maritime Series are actually applicable to wider uses. Contact a certified Peplink partner for a tailor-made solution!
How does one provide reliable connectivity for a large area while remaining connected to another location? Peplink knows how and did just that with a warehouse branch in Thailand. Deploying a wide array from Peplink’s portfolio, this warehouse found an affordable, yet reliable connectivity solution.
Even when you’re heading to the woods, getting farther and farther away from the cell tower, a nice router and a powerful outdoor antenna can still secure you an uninterrupted connection. Bring the BR1 Pro 5G and the Mobility 42G with you! These magical tools are gonna get your toughest mission completed!
Don’t just watch other people using it. Try it! Grab your BR1 Pro 5G when it is still in stock! This single little router can just give you what you want - either next-generation speeds and reliability on the way, or a 5G back-up to your work from home connection.
Cutting on downtime, cutting their losses, cutting costs ![]()
Sometimes, less is more! Take it from this American logistics company who switched out their MPLS network for a flexible SD-WAN solution.
I really like the graphics on the first image - the outline around the worker tied in with the headline background has a really nice look!
Being a techie doesn’t mean to be boring. You can make it your own style even when you’re using the most rugged and hard-core products, just like Peplink’s outdoor antennas. Be who you are, paint your antenna with whichever color you like, and enjoy the great signal that you always deserve!
Get to know more about what needs to be noted while painting your antennas.
How does information flow between your branches? ![]()
Whether a logistics company depends on email, IoT, APIs, EDI, or TMS, there’s still something they all need. Read about how logistics data and information flow from one end to another, and what makes it work.
Peplink works together with CTO Networks and Connectivity Solutions to complete a large-scale deployment for Qualitas Seguros, one of Mexico’s leading insurance companies. With our Balance portfolio, Qualitas’ Branch Network meets Reliable Connectivity. Read about this great connectivity breakthrough.
Your sea trip is about to begin. But before you set off, what do you need to prepare for offshore connectivity? A router? An antenna? Or an access point? Peplink’s certified partner, Onboard Wireless, has the answer and more. See how to stay connected while setting sail.
1 router, 28 nodes, several technologies, and endless possibilities - this is Peplink’s SpeedFusion Cloud. Achieve a more reliable network with Peplink and SpeedFusion Cloud. Catch these fast facts on SpeedFusion Cloud and learn all the basics of what it can offer you and your connectivity.
Peplink is excited to announce that more of our 5G devices are now Verizon certified and can be activated on the Verizon network. The MAX Adapter, MAX BR1 Pro 5G, and Balance 310X 5G are ready to provide you with reliable connectivity in a secure network.
While you are still wandering and seeking, someone has already found a simple yet satisfying 5G solution and been benefiting from it! Either for fast and reliable connectivity on the move, or a backup for your wired network, this user-friendly 5G router is definitely a good choice. Get to know more about our BR1 Pro 5G and grab yourself one!
Peplink prides itself in large deployments, but our portfolio’s versatility also supports small scale applications. A traveling graduate student achieves remote learning with stable connectivity brought by our devices and SpeedFusion Cloud.
Here comes Firmware 8.2.0! As one of the new features, SpeedFusion Cloud Relay can provide you more flexible access to the internet. Now, you can even access previously restricted applications. Want to know how to enable this new feature?
Instant multiple-carrier connections, maximum uptime, and zero contracts - these are what SpeedFusion Connect offers you. This Peplink-owned LTE and SpeedFusion Cloud plan will allow you to remain connected in the simplest of ways.
Feel the bonded connections are not fully utilizing your WAN capacity? Dynamic Weighted Bonding (DWB), another advanced new feature of Peplink’s latest Firmware 8.2.0, can surely help you! By combining connections with similar latency, DWB can prevent the overall performance from being affected by weak and unstable WANs.
Just a few days to go! Get ready for the IWCE 2022 where our certified partner GetWireless. LLC is going to impress you with how Peplink can safeguard your mission-critical connectivity! From March 21-24, they will be showcasing Peplink’s 5G products and overall portfolio at Booth 1526, Las Vegas Convention Center (North Hall). Don’t miss out!
