This is my Topology,
Sorry, I’m new to peplink.
If I have 4 wan connected to peplink what should I make as the outgoing interface in the FortiGate when creating a policy to have my endpoint devices have an internet connection?
Thank you for your Help
Hello…
Are you trying to use drop-in?
Thank you Marcelo for the great explanation.
I have some clarification for this.
for peplink connectivity to firewall. what port should I used in firewall LAN or WAN port?
THank you
Your internet service provider will be installed at WAN of Peplink
Your firewall will be instaled at LAN of Peplink.
You need to check the drop-in capability in your peplink device.
okay?
