hello
If you’re using a mobile device, you’re likely to be, well, mobile. Which means your experience will suffer if your device doesn’t know when to switch from the AP you connected with when you walked in the door to the one across the convention hall where you are now. Unfortunately, many devices get “stuck” to their previous AP for too long. This is especially problematic for voice and video applications, and a major source of frustration in high-density environments.
DID PEPLINK AP technology, can force clients to switch to a new AP when their signal gets too weak.?
users get better roaming. And, even more important in dense public venues, you won’t waste network capacity communicating with too many devices over slower, weaker connections.
SO IF PEP LINK SUPPORT ROAMING THAT FORCE CLIENT TO MOVE ANOTHER nearest neighbor AP ?
