HI,
We have VSAT system that will be used for cellular backhaul for remote area. Unfortunately the cellular provider need L2 connection with multiple vlan, while our VSAT system use L3 connection with max mtu 1632.
Is there away to adjust WAN mtu on peplink to 1632 ? so we can get maximum mtu for the L2 connection. We need to keep the mtu above 1500 after the tunnel if possible so there won’t be any problems with the cellular service also to utilize the VSAT bandwidth more efficient we don’t use packet fragmentation.
Thanks before.
