Forgive my ignorance on this topic, I am new to using VPNs. I have the Surf Soho. I am using VLAN to separate devices on my network for security reasons. I would like to be able to be able to access one of those networks from any location, using my laptop (MacBook Pro). Is this possible using PePVPN? Thank you!
Hi Itozer,
For PEPVPN you need 1 peplink device on each side of the VPN tunnel.
You could try and use IPsec VPN it isnt working as well as PEPVPN but it should do the trick.
Hope this helps you out ?
