Peplink switch Rugged 8 & 16 ports. Can get access to web interface and add to Switch controller
I have 2 rugged switch’s 8 & 16 ports.
According manual I did connection management port to pc:
Network settings on pc:
static IP 192.168.1.0
Subnet: 255.255.255.0
Trying open in web browser
http://192.168.1.254
Nothing.
Did factory reset, same.
Switch controller inside MBX HD4 did not see switchs.
In client list switch shown on 192.168.50.210
Any ideas how to open in to web interface or switch or make them visible by switch controller of router?
Do you have access to them in Incontrol2?
Isn’t Switch Controller only compatible with the new line of switches?
The rugged 8/16-ports are the previous generation.
Check the DHCP/Client list in your router to see which IP’s they’ve gotten on your local network, and you should be able to reach the web interface.
