Ref.: #38338
Published: 2026-10-29 [Last updated: 2026-10-29]
Status
Mitigation is available for the affected products, while pending for PHP update with the permanent fix.
Background
After the PHP2Shell vulnerabilities (CVE-2026-109618 and CVE-2026-109619) were announced last week, a new vulnerability (CVE-2026-115560) was found a few days ago this week, in which a web component that uses PHP session configuration could potentially be exploited for remote code execution. And reported in this post.
Details of the vulnerability can be found at the external reference link below:
The fix for the PHP2Shell released on 2026-10-22 (firmware 8.6.1s042) does not remediate this new vulnerability. It needs to update the PHP component configuration parameter to mitigate the exposure (set session.upload_progress.enabled=0, to a disabled state).
The Balance and MAX routers with Edge Computing (EC) feature enabled and running will be affected, as the EC feature utilizes a PHP component. The EC feature is disabled by default.
Other models and appliances (FusionHub and ICVA) are not affected.
Products affected:
Peplink Balance and MAX series with EC feature enabled, with firmware version up to 8.6.1s042, are vulnerable.
Mitigation
On Peplink Balance and MAX series with the EC feature, upgrade to the special firmware (8.6.1s054, based on 8.6.1s042) that changes the specific configuration parameter (session.upload_progress.enabled) to “disabled” at the system level. This change will be included in the next GA release.
Here are the direct download links for special firmware 8.6.1s054 (based on 8.6.1s042):
| Download Link | Product | Hardware Revision |
| Download | B One | HW1 |
| B One 5G | HW1-2 | |
| B One Plus | HW1-2 | |
| Balance 310 | HW5 | |
| Balance 310 5G | HW3 | |
| Balance 580X | HW2 | |
| MAX BR1 Pro 5G | HW3 | |
| MAX BR2 Pro | HW4-5 | |
| MAX Orbit 2 | HW1 | |
| MAX Orbit 4 | HW1 | |
| MAX Orbit 8 | HW1 | |
| MAX Transit Duo Pro | HW1-3 | |
| MAX Transit Pro E | HW2-3 | |
| Download | Balance 1350 EC | HW1 |
| Balance 2500 EC | HW1 | |
| Balance 310 5G | HW1-2 | |
| Balance 310 Fiber 5G | HW1-2 | |
| Balance 310X | HW1-3 | |
| Balance 380X | HW1 | |
| Balance 5000 EC (100G) | HW1 | |
| Balance 5000 EC (40G) | HW1 | |
| Balance 580X | HW1 | |
| EPX | HW1 | |
| MAX HD2 MBX | HW1-4 | |
| MAX HD4 MBX | HW1-4 | |
| MAX MBX Mini | HW1-2 | |
| PDX | HW1-2 | |
| SDX | HW1-4 | |
| SDX Pro | HW2 | |
| Download | MediaFast 500 | HW1-2 |
| MediaFast 750 | HW1 |
Pending PHP update with the permanent fix.
We will update this post if anything changes.
