Hi Support.
For the SDX, is the SFP+ 10G port backward compatible with SFP 1G? And what is the LACP mode: Active or Passive?
Regard,
Bit.
Hi Support.
Regard,
Bit.
Hi!
Yes, it should be compatible with SFP 1G mode, though you need to use a transceiver with verified compatibility. Here you can find the list.
On LACP - our devices use active mode.
Hi Sir,
Thank you response .
Regard,
Bit.
