The lates version peplink pepwave router utiliti ios 12, don´t acces a peplink balance 210 with version firmware 7.0.1 and 7.0.2, in the device event log show Admin: (XXX.XXX.XXX.XXX) login failed.
also in the fusionhub firmware 7.0.1 show the same mistake.
I’m having the same issue. Have you found a solution?
After upgrading from 1.4.9 to 1.5.0, I can no longer login to my router. I can login if I open up a web browser on my iPhone or any other device on my LAN and browse to 192.168.1.1.
Router Model: Peplink Balance 20
Firmware: 7.0.1 build 3414
Any time I open the router utility 1.5.0 app, I get a message in the event log:
(192.168.1.18) login failed
I submitted a debug report from the app yesterday, but I haven’t heard anything back from Peplink.
I just get the confirmation from Engineering team that Router utility v1.5.0 will have problem accessing Balance/MAX devices that running firmware below 7.1.0. Tentatively this will be fix for router utility v1.5.1 that will support devices firmware 6.3.0 or later.
For time being, please consider to upgrade your Balance/MAX devices using firmware version 7.1.0 and above and this should allow you to managing the devices using Router utility v1.5.0
thaks, the latest router utility v 1.5.1 solve the problem in the connetion
