- Hello, how are you guys? I’m Brazilian and I’m using the Google translator sorry for the mistakes. I am using peplink 305 + pfsense with the following scenario: My external IP that allows me to use services within my internal network via nat is the same one that is configured as the main DNS. Every time I try to set up multiple web servers within my internal network, pfsense informs me that a possible rebind attack is happening. I can’t access any web server on my internal network through the domain example.com.br Could someone guide me?
IP LAN IP LAN PEPLINK
PEPLINK --------------- PFSENSE ------ LOCAL NETWORK
WAN1 IP LAN LOCAL NETWORK
WAN2
This feels like a pfsense issue.
If the DNS records are within a domain name which you control and you are comfortable, you might consider turning off rebind attack detection for that domain.
https://docs.netgate.com/pfsense/en/latest/services/dns/rebinding.html
Also could try putting the hostname values into the override list, which will prevent rebind attack detection on those values.
where is this annulment list? Another thing when I configure the DNS on my web server it is trying to redirect to pfsense itself. I need to do some NAT rule
