Hi.
I have a doubt with OSPF operation in a balance, i know that speedfusion is routing through OSPF area 0 by default. First, can this operation be change?, can i change the area for a speedfusion to other that 0?
Second, can somebady confirm me that the nex topology can work with two ospf area 0, but separated by other areax? (i think that not, because two area 0 can´t work together)
Yes.
Area 0 is the backbone of OSPF. You shouldn’t have 2 area 0.
Thank you very much
This can work with two separate OSPF instances on one of routers and redistribution between instances.
Basicly you can use two area 0 on one router in different OSPF processes.
