i am wondering if anyone has used cradlepoints products and if so what did you think of them and which is more user friendly i currently have max trasnit cat-18 with the parsec antenna
I have used both, cradlepoint requires a yearly subscription for firmware updates and that’s the very reason I stopped using them, they also support fewer and fewer USB modems as time progresses. It’s a stable solution with a pretty good UI, but you won’t find any outbound algorithms like ssl persistence on them either. I am finding peplink support frustrating though, having to go through partners.
Well I am fairly new at this I’m not too familiar with a lot of the cloud and things like that is cradle points net-cloud more user-friendly then pep links in control 2
I would say it’s more complex than InControl.
