Peplink OpenVPN server hosting VPN, Ubiquiti connecting with error
Peplink and Ubiquiti support so far stumped
  • Peplink hosting OpenVPN server
  • Setup a network under network tab with a unique IP/range and VLAN ID not being used on the Peplink or Ubiquiti side
  • Set OpenVPN server on “Remote User Access” section to use that VLAN/Network under “Connect to Network”
  • Download the “Route all traffic” profile
  • Setup the connection on the Ubiquiti
  • It establishes the connection but has the error “Certain Routes provided by the server overlap with one or more VLANs and are ignored”
  • If I change the “Connect to Network” to my default untagged Vlan on the Peplink, the error disappears on the ubiquiti. However, I get the default network IP not the IP of the network that I want (to keep separate)
  • I checked the Ubiquiti and there are no conflicting IPs/networks on that range
Anyone have any ideas? Thanks!
@mystery understand that there is an existing support ticket for this; the case has been escalated to the Engineering Team, and we can continue to follow up via the ticket.
Thanks, also curious if anyone has any experience they can shed light on,
