Recently I have delivered three systems with a PEPLNIK ONE in the installation.
I use the as AP’S controller and as balancer with two BR1 MAX for Internet acces via WIFI or 4G/LTE.
THe issue I am having it seems the BALANCE one with no apparent reason it locks up.
Looking in the LOG I have seen it lock up after a time sinchronization …
I have learned that I can schedule reboots.
On the BR1 MAX the Schedule reboot is there but from th incontrol remote screen it seems it is not possible to do that!
Does it is only possible to do it locally from the internal LAN?
On the PEPLINK ONE I have not found this option!
Is there a way to schedule a reboot on PEPLINK ONE?
Thanks.
