Peplink Network Apps & Tools – Which One Works Best for Your Needs?
Peplink offers a range of apps and tools designed to cater to various user needs. You can select the ones that best suit your requirements and even use them simultaneously.
Managing a single router
Web Admin Interface - 192.168.xxx.xxx
The Web Admin Interface allows you to configure all router settings, view reports and logs. To access this interface, your device must be connected to the router’s network.
The URL is printed on the product label on the back of your router.
Peplink app
Peplink App (Learn more)
This app allows you to manage your router from anywhere, even when you are not connected to the router’s network. It is suitable for beginners, making it easy to set up their routers and configure basic settings. Its features include:
  • Create and share Wi-Fi networks
  • Configure WAN settings and swap their usage priorities
  • Enable SpeedFusion Protection for clients and applications
  • Prioritize usage for clients and applications
  • Monitor router status with real‑time notifications and reports
  • Upgrade firmware
Currently, the app mainly supports models with cellular WAN and Wi-Fi. We are working to expand the supported model list. (View supported model list)
Download
Router Utility app
Router Utility App (Learn more)
Unlike the Peplink App and InControl, this app communicates directly with the router, without using any cloud service. Your device must be on the router’s network to access it.
With the Router Utility App, you can view basic router information, such as WAN status, client list, and connect your router to SpeedFusion Cloud locations.
Download
Managing multiple routers
InControl Cloud Management
InControl enables you to manage multiple routers within an organization. You can view aggregated reports, apply bulk configurations, and organize routers efficiently.
Visit InControl 2
InControl app
InControl App
This app provides information about your InControl organization and groups, including router connection statuses, client lists, and event logs—all at your fingertips.
Download
Improve connectivity on mobile devices
SFC app
SpeedFusion Connect App (Learn more)
This app bonds the multiple internet connections (e.g. Free Wi-Fi & Cellular Data Plan) on your mobile device into a more reliable connection using SpeedFusion technology. A Peplink router is not required to use this app.
Download
